Problems setting up an iD SIM on an OPPO A37 phone
Has anyone successfully set up an Id SIM on an OPPO A37 phone? I have followed the guidance on this web site, but I can't make it work! If you have been successful, could you share your SIM settings?
Best answer by Kevin M
Howdy @Moufflon
Does your phone allow you to define which SIM your phone would use by default for data?
They might be an issue with a dual-SIM phone, or a setting there within.
Could you try removing the O2 SIM, deleting the O2 APN settings and trying if the SIM is working for data then?
Name iD
APN id
Proxy (no menu choice given)
Port (no menu choice given)
Username (no menu choice given)
Password (no menu choice given)
Server (no menu choice given)
MMSC http://mms.um.idmobile.co.uk:10021/mmscPPP Number (no menu choice given)
MMS Proxy mms.idmobile.co.uk
MMS Port 8799
MCC 234 (no menu choice given)
MNC 20 (no menu choice given)
Authentication type (choice of None, PAP, CHAP, PAP or CHAP)
APN type (no menu choice given)
APN protocol IPv4 (choice of IPv4, IPv6, or IPv4/IPv6)
APN roaming protocol IPv4 (choice of IPv4, IPv6, or IPv4/IPv6)
Bearer
Kevin
View originalDoes your phone allow you to define which SIM your phone would use by default for data?
Moufflon wrote:
Name iD
APN id
MMS Port 8799
Bearer
Kevin
Log in to the iD Community.
Social Login
