Hi there
I have a Samsung J3. For the last week or so I have been able to receive but not send SMS.
When I try to send a message I get the error message 'Message failed to send
I have tried/checked:
Sending a message to myself - still fails
Checked the message centre number- it's correct
Restarted the phone
Factory reset of handset
I don't have another device that's unlocked or on ID so I can't test the SIM in another phone.
I can receive messages fine and make and receive calls.
I'd be really grateful for any advice on other things to try.
Best wishes
Chris
Log in to the iD Community.
Social Login
