FIX FOR SLOW SPEED | iD Mobile Community
FIX FOR SLOW SPEED
  • December 16, 2023
  • 5052 views
DazTilly
like many since joining ID I have been plagued  with slow speed and I mean SLOW (1MPBS) and poor signal.
I found that the SIM had configured the PRIVATE DNS  to be Cloudfare however this is a pathetic DNS, and a Will slow Your network down. So here is a fix
Go to... Settings, Network and Internet.
Then .. set PRIVATE DNS to Off
Then.. reboot
Voila !
DazTilly
  • December 16, 2023
Or…
Replace with a decent DNS such as
dns.adguard-dns.com
dns.google.com
Etc.
  • December 18, 2023
Hi @DazTilly,
Thanks for sharing this and hopefully it will help another user.
DazTilly
  • December 18, 2023
Yes @Kash  I've never heard of seen any support staff mention this, and it explains slow speed (WiFi and cellular) AND poor 4G/5G signal. It's something that should be in a knowledge base with you guys 🤟
