If I have unlimited calls on my plan are 0344 numbers free? Thanks
0344 numbers
Numbers starting 03 are included in the calls allowance of iD plans,
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Please note: Log in with Facebook is no longer available. If you used this service, you'll need to create a password to keep using the iD Community. Click 'Forgot Password?' to get started.
