120Gb/month plan
I recently signed up to a 120Gb monthly data plan. On the app although it shows 120gb available it says my plan is for 1.5Gb/month. I have searched on here and it says it is a glitch with the mobile app and not to worry but the same 1.5Gb/month is showing when I log in to your website as well. I just want to confim I’m on the 120Gb/month plan
Viktor
Best answer by Digital_Veteran
@ViktorIvans
Your main allowance shows you still have 119GB remaining,  which confirms you are definitely on 120GB allowance.
It is just a glitch on the system which is why it shows 1.5gb.
(Probably the base plan is 1.5gb  and then it adds extra 118.5gb free, making a total of 120gb deal.)
Don't worry, everything looks good.
BUT i strongly recommend you edit your post and delete the image as it shows your personal mobile number!!
Digital_Veteran
  • 6 replies
  • April 9, 2025
@ViktorIvans
  • 8369 replies
  • April 9, 2025
Hi ​@ViktorIvans
