4g is not working
My 4G is not working on my phone, but when I put my SIM card in another phone it works and if I put a different SIM card in my phone it works so can’t figure out the issue. I have followed all the online advice but none of this has worked. Any ideas what I need to do?
JoeKing
Silver Contributor
Forum|alt.badge.img+9
  • Silver Contributor
  • 381 replies
  • March 27, 2025
@Pebbles28  Afternoon sound pretty strange here, are you able to go to a Curry's store with your phone and pick up a replacement SIM card?
I take it the phone and Sim was working before hand on 4G and is this device from IDMobile?
If you're unavailable to go to a Curry's store or into your IDMobile account under Plan and the Sim and Phone Management select Request a replacement SIM or eSim and follow the instructions.
Joe
  • 8 replies
  • March 27, 2025
I have been using the phone and SIM card for over a year and had no issues until now.
When putting the sim in another phone the 4G works
MZone
  • 1207 replies
  • March 27, 2025
Have you tried resetting network settings?
  • 8 replies
  • March 27, 2025
Yes, still the same
MZone
  • 1207 replies
  • March 27, 2025
What phone have you got?
  • 8 replies
  • March 27, 2025
iPhone 11
  • 8 replies
  • March 27, 2025
So I took it to the Apple Store in town but then it worked! So maybe an issue with my area? But when putting my sim in another iPhone 11 in the same location it worked so not sure.
  • 8 replies
  • March 27, 2025
How do I contact ID mobile?
MZone
  • 1207 replies
  • March 27, 2025
using the iD online Live Chat service, to speak to a customer adviser ​@Pebbles28
The advisers work until 8pm on weekdays and 6pm on weekends - just tell the 24/7 chatbot you’d like to “talk to a person”.
  • 4297 replies
  • March 28, 2025
Hey there ​@Pebbles28, we hope the kind advice from ​@JoeKing & ​@MZone has been able to help, and you were able to contact our live-chat.
I have just responded to your other post/comment, so please respond there if needed to avoid confusion between posts/comments.
