Just upgraded my phone to a 5g phone, question _ do I need a different sim card for 5g. Thanks
Best answer by Tom
You probably won’t need an updated SIM card to access 5G, however it’s worth noting only certain areas have access to 5G signals, you won’t get it everywhere.
