A13 phone charging
  • February 23, 2023
  • 6 replies
  • 60 views
Andy_kev
I received my a13 phone today, opened the box to charge the phone and find that the lead that comes with it has the same plug both ends of it (the plug will push into the phone) it doesn't have a usb plug on one end of the cable, how do i charge it???
Best answer by Mohammed H
Hey @Andy_kev,
You’ll need to purchase a new plug that has a USBC slot.
There are options that also have USBA and USBC slots that might be better suited so you can have a multi use charger.
  • 12548 replies
  • February 23, 2023
Yeah, that’s standard for USB-C charging cables these days.
Andy_kev
  • February 23, 2023
Andewhite, thanks for your reply, but how do i charge my phone as i can’t plug it into my usb plug!!
  • 12548 replies
  • February 23, 2023
You’ll probably need to buy a suitable charger, or get a USB-A to USB-C adapter.
Mobile phone manufacturers are not allowed to package a phone charger with a phone.
Too many transformers ending up in landfill.
  • 8309 replies
  • February 26, 2023
Hi @Andy_kev,
I hope that @andewhite has answered your question.
Geluk
Silver Contributor
Forum|alt.badge.img+10
  • Silver Contributor
  • 485 replies
  • February 26, 2023
Mohammed H
  • 7962 replies
  • February 28, 2023
Hey @Andy_kev,
