abroad roaming
Jordan Morley
I am currently in greece but have just recieved a text to say welcome to turkey and that i will be charged
MZone
  • 1213 replies
  • June 9, 2025
You must be picking up a mast from Turkey. To use roaming in Greece make sure you are using either of the following network partners.
HELLENIC TELECOMMUNICATIONS ORGANIZATION S.A. (OTE S.A.), Wind Hellas, Vodafone Greece
You should be able to search and select these manually rather than having the device use automatic mode.
  • 4541 replies
  • June 9, 2025
Hey there ​@Jordan Morley, we hope the kind advcie from ​@MZone has been able to help, and we’d recommend following his instructions above.
Furthermore, we’d advise changing your bill cap to £0.00 via the iD Mobile app/website when logged in, to ensure you don’t connect to roaming in Turkey, as you’d be charged for doing so.
