adult filter
  • November 22, 2024
  • 68 views
Hi I want to adult filter on
Daz_S
  • 1627 replies
  • November 22, 2024
Hi there ​@Ahmedbhai
It should have been on by default. But you can double check this by:
Using either the iD Mobile app or online portal, then
Plan → Manage your iD services → Adult content filter and toggle this on, then click save.
You may need to restart your device to be allocated the correct DNS.
HTH
  • 1995 replies
  • November 22, 2024
@Ahmedbhai -
Have the steps from ​@Daz_S been useful? Thanks.
