anyone else not receiving texts until days later??
For last month I've not been receiving text until days later after they've been sent.
I've tried turning off and on again , manual roaming to different network and check my number is correct .
Anyone else still having this issue, I think.its time to look at leaving
A
JoeKing
Silver Contributor
Forum|alt.badge.img+9
  • Silver Contributor
  • 372 replies
  • May 1, 2025
@Andy Solly  Here’s few thing's to try.
Check if there any issues reported in your post code area. https://www.idmobile.co.uk/help-and-advice/coverage
Delete the Message app cache only, and  update your message app and see if any of these make any difference to your service.
Joe
  • May 1, 2025
Cheers Joe.
Can you advise how I clear.messahe cache and also update the app.
  • May 1, 2025
Found that and done another reset, still no message coming through
Siân
Forum|alt.badge.img+5
  • 1019 replies
  • May 2, 2025
Hi ​@Andy Solly  sorry to hear this.
There may be some congestion in your area, have you checked your postcode here https://www.idmobile.co.uk/help-and-advice/coverage
Has this always happened, or is it a recent thing? Is it texts from the same number, or all texts?
