are landline calls included in my unlimited calls plan?
  • December 22, 2024
  • 508 views
Are landline calls included in my unlimited calls contract plan?
Best answer by Atkinsp213
Yes standard Landline and mobile calls all part of your contract unlimited calls same on all packages.
Daz_S
  • 1627 replies
  • December 22, 2024
Hi there ​@mrfm910
Yes if you’re in the UK and are calling a UK landline number, starting 01, 02 or 03 then they come out of your monthly allowance. If it doubt set your billing cap to £0 as this prevents any unwanted charges.
  • 8662 replies
  • December 23, 2024
Hi ​@mrfm910
Yes, calls to standard landline numbers are included, premium numbers would not be included.
As ​@Daz_S suggests, if in doubt, set the bill cap to £0, it’ll stop you from making any usage that would charge extra.
Forum|alt.badge.img
  • Helpful
  • 16 replies
  • December 26, 2024
