I have downloaded a barclaycard app and it says i shall receive a six digir code by text but its not arriving I do receive texts from other numbers but not from Barclays
any suggestions?
any suggestions?
Best answer by Kash M
It sounds like your OTP aren’t coming through.
You can try troubleshooting the issue using the link below:
https://community.idmobile.co.uk/troubleshooting-177
