Barclay card code
  • August 30, 2024
  • 111 views
Kleanth Dashi
I have downloaded a barclaycard app and it says i shall receive a six digir code by text but its not arriving   I do receive texts from other numbers but not from Barclays
any suggestions?
Best answer by Kash
Hi @Kleanth Dashi,
It sounds like your OTP aren’t coming through.
You can try troubleshooting the issue using the link below:
https://community.idmobile.co.uk/troubleshooting-177
  • September 3, 2024
Hi @Kleanth Dashi,
Kleanth Dashi
  • September 3, 2024
Hello Kash
This is sorted   I rang Barclay card services and I had to unblock come of the numbers   on the settings    Thank you for your help
  • 1984 replies
  • September 6, 2024
Glad you got it working @Kleanth Dashi - thanks.
