call
Android phone not working calls
Best answer by Tom
Hi ​@mhmalawi
Okay, taking a look I don’t believe we officially support this device, usage of our SIM inside that device may not work properly.
  • 12380 replies
  • March 13, 2025
But your mobile data (Internet) and SMS texts OK, ​@mhmalawi
  • 4228 replies
  • March 13, 2025
Hey there ​@mhmalawi, sorry to hear that.
What phone do you have and what’s your full postcode please?
  • March 13, 2025
Cat 62pro
Bl3
  • 8408 replies
  • March 14, 2025
Hi ​@mhmalawi
Decembersangel72
Silver Contributor
Forum|alt.badge.img+12
Hi ​@mhmalawi
Do you have VoLTE enabled on your handset? You will need to have this turned on for use on every network.
To enable VoLTE (4G voice calling) on your CAT S62 Pro, navigate to Settings > Network & Internet > Mobile Network and look for an option like "Enhanced 4G LTE Mode" or "VoLTE" and turn it on.
If you can send/receive texts and use your data but not be able to make/receive calls then this is probably why.
Good luck x
