On making calls it immediately say call ended without connecting. Can’t even access voicemail. This is the screen shot. Anyone know what’s going on?
Best answer by Kash M
Do you have the issue in all areas even away from home?
Have you tested the SIM in a different handset?
You may have a faulty SIM but we can get a new one sent or you can collect a replacement from your local Curry’s store.
