Been told I can make calls whilst I’m in Egypt and will pay the costs on my next bill. I’ve tried a couple of times to call out but they won’t go through. I have mobile data on - is there something else I should be doing?
Calls FROM Egypt
Best answer by MZone
Check your spend cap isn’t set to £0. Also make sure you’re using the correct country code when dialing.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
