Calls FROM Egypt
Dora Boulding
Been told I can make calls whilst I’m in Egypt and will pay the costs on my next bill.  I’ve tried a couple of times to call out but they won’t go through.  I have mobile data on - is there something else I should be doing?
Best answer by MZone
Check your spend cap isn’t set to £0. Also make sure you’re using the correct country code when dialing.
MZone
  • 1207 replies
  • March 19, 2025
Dora Boulding
  • March 20, 2025
Of course.  Had my spend cap set to £5 and I must have used that.  Thanks
  • 4297 replies
  • March 21, 2025
Hey there ​@Dora Boulding, we’re glad to see that ​@MZone was able to assist you!
Thank you ​@MZone!
Kind regards,
