Calls straight to voicemail
I'm repeatedly getting important calls (Bank, school, hospital etc) going straight to voicemail without ringing. I've tried every setting, still nothing. There doesn't seem to be a fix in the forum and I can't try my esim in another phone. Has anybody managed to solve this yet?
  • 8661 replies
  • March 11, 2025
Hi ​@Ududbfhd8ejr
I’m sorry to hear this, have you tried dialing the following?
61*12330#
This should make the ringing as long as it can be adjusted to at 30 seconds.
  • 9 replies
  • March 27, 2025
Hi, I just tried this as getting same problem and it shows USSD code running then connection problem or invalid MMI code. My phone status shows 4 bars, WiFi connected with 4arcs and 2 arrows and WiFi calling.
  • 6232 replies
  • March 28, 2025
Hey there ​@Corrin, sorry to hear that.
What phone do you have and what’s your full postcode?
Have you always had this issue with us, or more recently?
Is it only calls from businesses/landlines etc that you’re missing, or normal mobile numbers too?
  • 9 replies
  • March 28, 2025
Hi, my phone is Samsung A34 5g. My postcode is WD18 7SA. It started in November, I only noticed it from landlines then as don't get many calls. Yesterday I was waiting for an important call and it went straight to voicemail this could have been from a mobile, landlines or business phone.
  • 6232 replies
  • March 31, 2025
Have you tried disabling, and then re-enabling voicemail via the iD Mobile app/website?
Do you have call forwarding enabled?
  • 9 replies
  • March 31, 2025
Yes, I have call forwarding but I cannot disable it when unreachable
  • 9 replies
  • March 31, 2025
  • 2374 replies
  • March 31, 2025
Thanks ​@Corrin
Apologies, just to understand, what happens when you attempt to remove the call forwarding?
Natalie
  • 9 replies
  • April 1, 2025
I get  message Unable to deactivate call diverting when phone is unreachable. Unsupported by operator
  • 8661 replies
  • April 3, 2025
Hi ​@Corrin
Please could you try the following?
#330*0000#
  • August 22, 2025
Hi - I too am having the same issue with calls going straight to voicemail. I am unable to deactivate the call forwarding. The message I get is "Faied to read data. Unable to deactivate call diverting when busy. Unsupported by operator".
  • 8308 replies
  • August 26, 2025
Hi ​@Tortielicious,
Kashif
