Calls to some UK numbers failing
Calls to some UK numbers fail with 'server unreachable' error.  Latest was a Coventry code 02476 to FedEx. Note that this happens to me (Android phone) and my wife (iPhone 11pro).
Both phones up to date with software, both been reset and both had settings checked and look OK.  Other calls work fine.
Anyone got a solution apart from dumping ID? 😁
Tia
John
Best answer by WelshPaul
There’s nothing wrong with your iD Mobiles, the number you’ve given above simply doesn’t work. I’ve tried calling it from my landline, Vodafone Mobile, and iD Mobile, but the number doesn’t work on any of them.
  • 4228 replies
  • May 21, 2025
Hey there ​@Barra175, we’re very sorry to hear that. Is there an issue with FedEx/the phone number at all?
Does this happen to any other calls you make to any other numbers?
  • May 21, 2025
Seems there may be an issue with the FedEx number although we (both my wife and I) have had the same issue with other numbers.
Tried some stuff on the advice given on the chat so time will tell if they've helped.
Thanks for the response
John
Siân
Forum|alt.badge.img+7
  • 1225 replies
  • May 21, 2025
Are you both on iD ​@Barra175
Are they all local numbers, not premium numbers?
  • May 21, 2025
Yip, both iD. Not premium.
John
Siân
  • 1225 replies
  • May 21, 2025
OK ​@Barra175 , can you possibly give me an example of a couple of the numbers you are trying to dial, the full number? Say, if it is a business or something?
  • May 21, 2025
As I said in my original post, it was a business (FedEx) with a Coventry code: 02476706695. That's the number that you call when their app can't find your parcel.  Not that it matters as the parcel was delivered yesterday.
Apart from that, I don't have a record of others. Sorry.
Terry Walton
  • May 21, 2025
Tia
John
That sounds like a possible on the recipient side, are they on the same network?
  • 4228 replies
  • May 22, 2025
Hey there ​@Barra175, thank you for that.
Do you still require assistance with this with the parcel now being delivered?
  • May 22, 2025
Hi Tyler,
Don't think so. Unfortunately I can't provide any more details or numbers as it is infrequent. As folks have said it may just be faults at the receiving end.
Thanks All.
  • 4228 replies
  • May 22, 2025
No problem at all, thank you for the update and sorry it wasn’t working ​@Barra175.
Kind regards,
  • 3039 replies
  • May 22, 2025
  • May 22, 2025
Hi WelshPaul,
Thanks for the confirmation.
Siân
  • 1225 replies
  • May 23, 2025
Hi ​@WelshPaul  thanks, that's what I was going to try as that was my suspicion that the number wouldn’t work.
Glad you got your parcel sorted ​@Barra175  but if you need help with anything else, please let us know.
