Can I add a LTE Galaxy Watch Ultra to my plan
  • November 21, 2024
  • 1854 views
Mark Lang
I’ve tried to add a mobile plan for my Galaxy Watch Ultra but it says that it couldn’t set up your plan, make sure your phone is connected to a mobile network, then try again.
The phone is connected to my iD network, this worked seamlessly when with my 3 network.
Has anyone managed to add a watch to their plan?
Mark
Best answer by Daz_S
@Mark Lang
I don’t think iD Mobile offer a Smartwatch Pairing Plan.
Though it might be worth waiting to see if an iD employee can check on this, as (you already know) Three do and iD piggyback on Three. If they confirm they don’t then its another missed opportunity IMO.
  • 12595 replies
  • November 21, 2024
Unfortunately ​@Mark Lang, iD Mobile eSIM products can’t be used in wearable devices.
Daz_S
  • 1626 replies
  • November 21, 2024
@Mark Lang
  • 12595 replies
  • November 21, 2024
Here’s a recent response on this subject from the iD Community Manager, ​@Daz_S
Daz_S
  • 1626 replies
  • November 21, 2024
Thanks for clarifying that ​@andewhite 👍
  • 2042 replies
  • November 22, 2024
Thanks for the contributions ​@andewhite ​@Daz_S. Hopefully that answers your question ​@Mark Lang. Thanks!
Mark Lang
  • November 22, 2024
Daz, Ande and Mathew, thank you all for taking the trouble to respond to my question, which is really appreciated. I must admit I forgot to check that it would work before taking out the plan, I wrongly assumed as they were tied in to Three it would be supported. I hope I don’t regret my decision as I’m now tied in for two years, hopefully they’ll add it sometime soon.
Daz_S
  • 1626 replies
  • November 22, 2024
Honestly ​@Mark Lang it was no problem at all.
But if you’re within 30 days of opening the account, you could always cancel.
You’d have to pay for the usage up until you cancel and they should refund the remainder. Just leave the DD open until those funds are returned.
By the sounds of it you continued using your phone, so there’s no returns cost either.
Anyway its something to think about.
