I sent a fone back and cancelled monthly contract so sim went to pay as u go can I get another monthly contract with new fone and still keep my number withID or is the only way to get off pay as u go is by changing provider
changing tariffs
Best answer by Tyler C
Hey there
If you’re already on PAYG with us, then you cannot transfer your phone number from one iD plan to another I’m afraid. You can only do so via a triangle port, where you transfer your number to another network, then back to us on the new plan, which we can explain in further detail if you wish.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
