changing to old number
I had an old number a while ago that I think was with ID but I have recently changed numbers twice. My current number is ID but I was wondering if I can change it to my old one? Thanks
  • 12348 replies
  • March 21, 2025
Unfortunately @Wood678, your ‘old’ number has probably been recycled for use elsewhere if you’ve not been actively using it - for calls, texts, or mobile data - nor paying a monthly subscription to a service provider.
Mobile networks assign numbers randomly, so you’re unlikely to be able to change to your ‘old’ number.
  • March 21, 2025
Do you think I would be able to contact the person with the old number? I only need a code that can only be sent to the number.
Decembersangel72
Silver Contributor
Forum|alt.badge.img+12
Hi ​@Wood678
As you no longer have access to your old number and you require a code that will be sent to it…... is there an option to have a code sent to you via your email (as long as it hasn’t changed)?
Usually, there is an option to get a code sent via a different method when needed.
I know, personally, that sometimes it is easier to get codes sent to me via my mobile number but other times I request one to be sent to me via email and there is always the option to do so.
Other than that, you can try to ask the new owner of your old number if this is acceptable, BUT like myself, I would probably assume that it is a scam and ignore the request.
You could also contact the Customer Services of company you need the code from and explain the circumstances so that they can change your contact number to the one you have and then you can get the code you require now and in the future.
Good luck x x
  • March 22, 2025
It only gives me the option of sending it to the number, I’ve asked customer service and they’re really no help they just say they can’t change it.
Decembersangel72
Silver Contributor
Sounds about right with regards to CS reply but understandable!
Which company are you trying to get a code from?
I’m sure that I’ve seen similar questions on other Community pages I am part of and I can have a look to see if it has been asked.
  • 12348 replies
  • March 24, 2025
If you don’t have the mobile number, then perhaps iD Mobile suspect this is a fraudulent attempt to obtain a mobile number, ​@Wood678
  • March 24, 2025
Hi ​@Wood678,
Is the OTP code that you need to receive?
If you still require assistance, please get back to us and we can PM you.
  • March 24, 2025
@Decembersangel72 its for Snapchat. I have been trying to get into the account for ages and I have the password and the email connected to the account. But says it needs a code which would be sent to my old number. I asked Customer Service and it’s just automated replies.
  • 12348 replies
  • March 24, 2025
To web chat with an iD customer adviser, just tell the helpful 24/7 iD chatbot you’d like to “talk to a person”, ​@Wood678
The iD advisers work until 8pm on weekdays.
  • March 25, 2025
Hi ​@Wood678,
I hope that you managed to get this resolved.
If you require further assistance, please feel free to get back to us and we can PM you.
Decembersangel72
Silver Contributor
Hi ​@Wood678
I have found this information with regards to getting verification via email…..
https://beebom.com/how-reset-snapchat-password/
(scroll down to ‘Reset Snapchat Password Without Phone Number’)
You can also try these:-
  1. Contact Snapchat on the mobile app by going to "Settings," "Support," then “Contact Us.” (Unless this is what you have already ttried)
  2. Visit Snapchat's ‘Submit a Request’ page to contact them on desktop.
  3. Reach out to Snapchat on X @snapchatsupport for quick assistance with a problem.
  4. Contact Snapchat via email support@snapchat.com
  5. https://www.lifewire.com/contact-snapchat-customer-service-4584117
Number 3 seems to be the best option as there are mixed results reported for contacting via email (but still worth a try!)
There is also this…..
https://help.snapchat.com/hc/en-us/articles/15616633664148-I-can-t-verify-my-email-or-mobile-number
I hope something here helps!
Good luck x
Forum|alt.badge.img+21
  • 2215 replies
  • May 5, 2025
Thanks for your assistance with this ​@Decembersangel72
Natalie
