Charged for 07893 number
MarkK
I was charged for calling two UK numbers, both starting with ‘07893’.  Is this a special category number that is not included in my unlimited minutes?
Best answer by WelshPaul
https://www.idmobile.co.uk/nonstandard07numbers
  • 12248 replies
  • June 7, 2023
The 07893 number is apparently a Non-Standard 07 number.
Check online at https://www.idmobile.co.uk/help-and-advice/call-charges (see the here link).
Non-Standard 07 numbers are charged at 40p/min.
  • 2897 replies
  • June 7, 2023
Need the next digit not all 07893 numbers are mobile numbers.
MarkK
  • June 7, 2023
9 is the next number (078939)
  • 2897 replies
  • June 7, 2023
  • 8352 replies
  • June 9, 2023
Hi @MarkK
Unfortunately the number beginning with 078939 would be chargeable, we’d recommend adjusting your bill cap to a comfortable amount to avoid unwanted charges in the future.
Thanks @andewhite & @WelshPaul for the help here.
