  • September 1, 2024
  • 28 views
Having started an up grade to get 4g as 3g is soon to be turned off I find that,4g reception is insufficient to be able to use phonecalls from my house. Highly unacceptable Any suggestions?
Geluk
Silver Contributor
Forum|alt.badge.img+10
  • Silver Contributor
  • 463 replies
  • September 1, 2024
Check network connectivity-
ditto rival networks.
  • September 2, 2024
I have and you wouldn't believe it,but my house and 3 adjoining houses are not covered on the 4 g map. That is out of the whole local area. " Sods Law"!!
  • September 5, 2024
Hi @Eric Heavisides,
Sorry to hear that.
If you are out of contract it may be best to move to a different provider that can keep you connected at your address.
