Data
  • September 25, 2024
  • 69 views
  • 6 replies
SMS says I gave used 100% of my data. App says I have 15GB. Which is true and which is false?
Best answer by Kash
Hi @nfiner,
Is any of your data an add-on?
If so this will start after the plan allowances have been used so you’ll get the text once the data has been used.
  • October 1, 2024
Hi @nfiner,
  • 6 replies
  • October 1, 2024
No. You have completely missed the issue. I received an SMS saying i had used all my data  but app said i had loads ( carried over). I still don’t know which was correct.
  • 8408 replies
  • October 4, 2024
Hi @nfiner
Have you made an upgrade recently?
