SMS says I gave used 100% of my data. App says I have 15GB. Which is true and which is false?
Data
Best answer by Kash M
Is any of your data an add-on?
If so this will start after the plan allowances have been used so you’ll get the text once the data has been used.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
