Data
Hi. I have taken my SIM out to activate a Spanish ESIM and my SIM’s mobile data doesn’t work now. What shall I do?
Best answer by WelshPaul
You need to configure your phone to use the eSIM of your choosing as the default connection for data.
  • 3099 replies
  • May 9, 2025
  • 8552 replies
  • May 9, 2025
Hi ​@Anabel
I’d recommend the same as ​@WelshPaul above, you may need to select which SIM you want to do which job.
Sadia Moaeed
Helpful
Forum|alt.badge.img
  • Helpful
  • 40 replies
  • June 24, 2025
Unused data does it roll over every month that is unused . What hat happens unused data not used and roll over .
  • 2349 replies
  • June 24, 2025
Hi ​@Sadia Moaeed
Thanks for posting.
Information on data rollover can be found here.
Please let us know if you have any further questions.
Natalie
