data roaming in Turkey
I know internet doesn’t come with uk internet but how can I use my internet in turkey. Do I need to buy add ons or will it just bill my account. Also mobile data isn’t working at all any advice. Struggling with this APN settings or how to find them, as only thing I can think why mobile data isn’t working?
If you’re roaming in Turkey, with your iD SIM card, you’ll be charged £1.50 per MB for your roaming Internet data, @Nathy1
Your iD account bill cap will need to be high enough to cover likely Internet data usage costs in Turkey.
Using 10MB/day = £15/day
Using 100MB/day = £150/day
Ouch!
  • 12167 replies
  • June 4, 2024
Ouch!
  • 8175 replies
  • June 10, 2024
Hi @Nathy1,
I can see that @andewhite has answered your query.
Laura Louise Leonard
Is there like a 7 day data roaming pass we can purchase or is the only option £1.50 per MG?
  • 12167 replies
  • June 11, 2024
Roaming passes aren’t available from iD Mobile, @Laura Louise Leonard.
Just get a travel data-only eSIM for Turkey, @Laura Louise Leonard - assuming your handset is eSIM capable.
Ooh thank you super helpful, I’ve never heard of these but will certainly check them out!  And yes I can take an eSIM did it for the first time last week!
