I know internet doesn’t come with uk internet but how can I use my internet in turkey. Do I need to buy add ons or will it just bill my account. Also mobile data isn’t working at all any advice. Struggling with this APN settings or how to find them, as only thing I can think why mobile data isn’t working?
data roaming in Turkey
If you’re roaming in Turkey, with your iD SIM card, you’ll be charged £1.50 per MB for your roaming Internet data,
Your iD account bill cap will need to be high enough to cover likely Internet data usage costs in Turkey.
Using 10MB/day = £15/day
Using 100MB/day = £150/day
Ouch!
Reply.
