data rollover
  • February 10, 2025
  • 117 views
My new contract says im on 10gb per month.
my account is saying i have 109.8gb/10gb.
what does this mean?
thanks
Best answer by Daz_S
Sounds like you might have previously been on an 100GB data allowance and you renewed to a 10GB data allowance.
The amount of data showing to the left (on the account or app) is how much you have carried over from the previous month (and this figure would reduce during data usage) and the amount to the right is your actual normal contracted data allowance.
So in your case for this months billing period you carried over most if not all of your previous months 100GB allowance and this was added to your new 10GB allowance (I’d say the 109.8GB is in black and the 10GB is in green on your account)
The following month you might see 20GB/10GB as you can only rollover the previous months unused allowance. Therefore if you don't use ~100GB during this months billing cycle you lose it when the next months billing period starts.
Again as an example  - you then use 15Gb in that month, the remainder of 5GB would be carried over to the following month  (15GB/10GB)
Forum|alt.badge.img+21
  • 2137 replies
  • February 13, 2025
Hi ​@bobomartin
We apologise for any confusion caused.
Can you please confirm if you were on another tariff with us before this one?
Nat
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • February 14, 2025
  • February 14, 2025
I was on a 10gb tarrif last contract.
new contract the same
thanks
  • 2137 replies
  • February 16, 2025
Thank you ​@bobomartin
When did your new contract begin please?
Nat
