My son has an IPhone 13. He is using data like water. It’s an ongoing issue but he’s just used 16GB in 4 days. He has previously enabled low data mode and says he’s turns the data off when home. I have no idea how I can find out what is the data being used on. Any ideas?
Data Usage
Best answer by JoeKing
As for what is actually consuming this vast amount of data you'll have to go into the Phone's settings for this.
Plus there over things like AI technology which uses real time and news a data connection.
Hope this helps you.
There are thing's you could put into place which limits the time connected to the mobile data once again you'll have to check with your phone's manual for this.
Joe
Log in to the iD Community.
Social Login
Log in with FacebookPlease enter your email address. If it matches our records, we'll send you instructions to reset your password.
