Diverting/Forwarding [un-answered] calls to another network
  • February 27, 2020
  • 98 views
I know the “settings->call divert->enter number” method but thats not exactly what i want...i want unanswered calls only to divert to a next number. The settings method diverts ALL calls, which is not what I want.
Can anyone help me out??
How do i divert/forward un-answered calls to another network only??
Kevin M
  • 2535 replies
  • February 28, 2020
Hi @Anynamewilldo
What phone are you using currently?
Does your phone not allow you to modify or play around with how exactly the Call Divert function works for you?
  • February 28, 2020
Hi Kevin
  • its iphone 7 latest update
  • the function diverts ALL calls - I want to bounce missed calls only to my other phone, like an alternative voicemail
Mohammed H
  • 7962 replies
  • March 2, 2020
Hello @Anynamewilldo,
Try dialling **61*111*20# and calling this.
Edit: You may need to have the Call divert function first enabled.
Try both enabled and disabled as I can’t recall the exact steps for this.
Let us know if this works.
