Dongle
  • 30 April 2024
  • 34 views
Hello,
I’ll be in Ireland (ROI) for around 4 weeks. Staying in a converted minibus. What advice/recommendation can you give for me to link my phone with iD Sim to my laptop to use my WiFi data?
I’ll be checking emails, bank accounts weather, Google maps and the odd browsing. Not after large data with  downloading Netflix, streaming  films, etc….
kind regards
Richard
Hi @MrDS
If you’re using your iD Mobile SIM card in a supported mobile device, you should just be able to start a hotspot and connect other devices to it.
We don’t officially support any dongles.
Hello Tom
thank you for the reply.
However, being a 69yo, the  -
Is lost on me can you explain what this is and how to set it up?
kind regards
Richard
Hi @MrDS,
Which make and model handset are you using?
You should see the personal hotspot settings in your network or connectivity settings.
If you have any issues, please get back to us.
Hello Kash
thanks for the reply.
phone is  realme 8 5G.
Will try ‘linking’ my phone with laptop to check if I get wifi from phone this evening,
kind regards
Richard
Hi @MrDS,
Please let us know how you get on.
