Doro Phone
  • September 16, 2024
  • 1507 views
I currently own a Doro 6520, which is only 3G, and will need replacing. I am looking to purchase a replacement Doro, which will be 4G compatible, and I believe, needs VolTe.
When I purchase the new phone, I believe it will be just a simple matter of swopping over the sim, and the new phone will take over.  Does this sound right?
Mavis
Best answer by Kash M
Hi @MavisW,
I would advise checking our 4G Calling compatible handsets via the link below:
https://www.idmobile.co.uk/4g-calling?srsltid=AfmBOoq8YmSZZ8Ip5LNSqEJeebBySzZCpyoF-oYt1EGOb5l4TWsOEZHj
There are only 3 Doro devices listed.
  • September 18, 2024
Hi @MavisW,
  • September 20, 2024
Hi Kash,
Thank you for your help. I ordered a DORO 6820, one of the ones you mentioned. All is working now after transferring my SIM card.
M
  • September 24, 2024
Hi @MavisW,
Glad to hear that this is resolved.
