Dual sim with two different numbers - what would i need to do
  • September 26, 2024
  • 132 views
Kingsizefairy
after I wasted over an hour in a pointless chat, I will try my luck here.
I have an account and a number with ID, which is due an upgrade (for my business)
I would like to upgrade to a mobile with dual sim.
I also have a contract and a number with a different provider (my private number), which I would like to move to ID
The plan is to use the dual sim mobile with my business and my private number. I need to keep both numbers.
what is the way forward?
The most important bit for me is the transfer from the other provider. Would I need to open another account with a sim only number? How does it work?
thanks in advance
Best answer by WelshPaul
1.Upgrade your original iD Mobile plan and choose a handset that offers dual SIM capabilities (e.g iPhone).
2. Purchase a new SIM only plan and select eSIM.
3. Install eSIM on device you obtained in step 1.
That’s pretty much it!
Just a heads-up, iD Mobile is for personal use only, so don’t mention business use. 👍🏻
  • 2972 replies
Kingsizefairy
  • 8 replies
thanks paul, I changed the wording ;-)
  • October 1, 2024
Hi @Kingsizefairy,
