Eu roaming text
Hi I’m on holiday in canaries islands and checked on the ID website which says roaming is from my allowance upto 30gb. But I’ve had a text the day I landed saying all calls, text and data are chargeable. Does that mean I’m being charged to use my phone or is it coming out of my plan?? I’m really confused
You can use your plan allowances in the Canary Islands, @Kazza77.
To avoid any out-of-plan charges, just set your iD account bill cap to £0.
  • 12543 replies
  • June 11, 2024
  • 8552 replies
  • June 26, 2024
Hi @Kazza77
As long as you’re connected to our roaming partner in the Canary Islands (in this case, Yoigo and Movistar) you won’t be charged extra for usage within your allowance.
In any case, if you wish to avoid any extra charges ever happening, a £0 bill cap will help.
  • July 24, 2024
I am currently on holiday in Rhodes and have had no issues with my phone until I went on a trip to Symi which is still in Greece but received a text saying “looks like you are outside of the EU roaming “ then I also received a text saying “you have used 80% of you Capped amount” I have no idea why I would have received these text and used any of my Cap while still in Greece
  • 8552 replies
  • August 1, 2024
Hi @Baglin
It sounds like you may have connected to a satellite network while on a boat, I’d recommend checking the following;
