Full signal and 4g but not working
Everywhere I go I get around 2-3 bars of signal and the 4g/5g badge pops up but when I try to use my online apps and websites nothing loads even though I have good signal. Pourquoi?
Best answer by JoeKing
@Jake Sheffield  Even that you have been getting these signal reading there are many factors why some people get faster or slower even non-responsive network activity.
Try putting you phone into Airplane mode for 2 minutes and turn off airplane mode and try using the phone normally.
Just to add have you check if there had been any reported network issues in your postal area this may also be a possibility to you ongoing problems.
Also you may want to try factory reset of your phones network settings as outline below.
iD Mobile Specific Information:
  • If you're having trouble with your iD Mobile data, you can try resetting your phone's network settings:
    • Go to Settings.
    • Go to Carrier.
    • Tap Automatic to disable it.
    • Tap any network that is not iD.
    • Wait for network selection to fail.
    • Update network search from manual to automatic.
    • Your network selection should be done and your data connection should be reset.
Joe
JoeKing
Silver Contributor
Forum|alt.badge.img+9
  • Silver Contributor
  • 373 replies
  • March 13, 2025
    • Go to Settings.
    • Go to Carrier.
Joe
  • 12347 replies
  • March 13, 2025
Is the mobile data setting turned ON for the phone with your iD SIM, ​@Jake Sheffield
Are you using your iD SIM in an iD approved phone?
  • March 13, 2025
@andewhite It was the first thing I checked 😂. I wanted to be sure it wasn’t a setting I turned off before asking around, thanks anyways though.
@JoeKing I’ll try those options, thanks.
  • 4175 replies
  • March 13, 2025
Hey there ​@Jake Sheffield, sorry to hear that.
What’s your full postcode and what phone do you have please?
