going abroad
Barbara Cooke Mills
I am going to turkey do you have a plan that allows me to use my SIM when abroad
Nothing for Turkey is available from iD Mobile, @Barbara Cooke Mills
Maybe the best options are:
  • Use the hotel Wi-Fi network.
  • Buy a local SIM upon arrival.
  • If your handset is eSIM capable, but a data-only eSIM with a travel plan for Turkey.
  • 12548 replies
  • July 15, 2024
  • 8661 replies
  • July 29, 2024
Hi @Barbara Cooke Mills
You’ll be able to use your iD Mobile SIM in Turkey, however it would cost extra, details on how much can be found below;
It may be worth exploring @andewhite’s suggestions.
