Help. In Thailand reached my capped limit and phone is now blocked!
  • November 10, 2024
  • 6 replies
  • 111 views
Kate Austin-Smith
Please can someone from ID mobile contact me urgently. I am travelling in Thailand and my phone has been blocked due to the capping limit, so I cannot make any calls without adding money to my account which isn’t possible as the live chat isn’t accessible for some reason and there is nowhere to do this on my account. Help please!!
Best answer by Daz_S
Or do you mean you can’t find where to up this limit?
Via the app → Bills → scroll down to Manage bill cap → set it higher there and click save.
Does this help too?
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 10, 2024
Hi there @Kate Austin-Smith
I can see you’ve mentioned your account, but have you tried using your online account and not the iD mobile app?
If not you could try here - http://my.idmobile.co.uk/ obviously you’d need to latch onto a Wi-Fi network if you’ve used up your billing cap.
Does that help?
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 10, 2024
Does this help too?
Kate Austin-Smith
Thanks Daz. I’ve worked out how to up my limit but my phone is still blocked for some reason. Any ideas how to remove the block? Thanks for your help!
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 11, 2024
Hey no problem @Kate Austin-Smith
It may take a while for the updated limit to go through. Have you simply tried powering the phone off and back on?
(yes I know that sounds silly, but when the SIM ‘talks’ to iD it might give it a kick up the botty!)
Kate Austin-Smith
Thank you I haven’t tried that but I will do! Appreciate your help.
K
  • 8369 replies
  • November 11, 2024
Hi @Kate Austin-Smith
You’ll want to raise your bill cap to allow for more charges, however there is a limit and while roaming in Thailand, you may hit that quite quickly.
