help my son card will not read in my phone since senor to load esim
  • February 10, 2025
  • 20 views
I had a software update and tried to load an ESim which failed.
Now it says sim card not loaded
I have tried both slots
Did hard reset
Did network reset
No network available to select
Says sim unknown
Unknown number
Sim works fine in other phones don't want to do full phone reset if there is a fix
  • February 15, 2025
Hi ​@STroller70
We are sorry to hear of the issues you are experiencing with service.
The eSIM is a digital SIM and not a physical SIM card so you would download this on to the handset via the email.
If you currently have a previous SIM in the phone, we would recommend removing this.
Can you please confirm if you have received the email with the eSIM on.
Nat
