Help no signal or data
Ezmeralda Edwards
Help! I'm in Wales, coverage checker says there should be signal, but there isn't. I have no phone signal or data, and I need sat nav to find where I'm going!!!
Please help. I've turned my phone on and off repeatedly and re-started, but still no signal.
Help!!! Please!!!!
I've even tried removing the SIM, but haven't got a needle to poke in the hole.
I'm really struggling without sat nav, and am not sure of how I'm going to get where I need to go.
Please help!
Cheers Ezzy
Best answer by Matthew T
Hey @Ezmeralda Edwards,
I’d recommend downloading Offline Maps for Wales so you can navigate without Mobile Data. This can be done in both Google and Apple Maps.
Geluk
Silver Contributor
Forum|alt.badge.img+10
  • Silver Contributor
  • 461 replies
  • August 30, 2024
Buy a satnav device, or a map?
Check if there are issues in your area at:
  • 1880 replies
  • September 2, 2024
