Help please
WelshWife
Since I installed ID mobile on my iPhone, I have been able to use it only on rare occasions but I can use WhatsApp when I am walking far away from home in our rural idyll. I try and make calls using ID mobile from home and the call ends as soon as is dialled, there is no ringing tone.
But when I immediately call the same number from our landline is rings and is answered. 🤬.
My husband has Three on his mobile  which works perfectly from home. 🤬
Our market town has WiFi but it doesn’t work for me 🤬
I have two numbers on my mobile data, one is my chosen number that I brought over from EE and the other is one assigned to me by ID mobile .
i need to sort this out. There is something wrong
PLEASE HELP
Thank you
Pinned reply
May 24, 2025
@WelshWife I think you have deleted the iD eSIM instead of the EE eSIM. Delete that eSIM off the phone so you have no eSIM’s whatsoever and then order a replacement iD eSIM and install it. Also check your SIM card slot on the side of your iPhone as you may have a physical EE SIM card in that. If so remove it. You’re getting no coverage cause the eSIM/physical SIM showing in the picture is the EE one and that’s been disconnected!
MZone
  • 1203 replies
  • May 23, 2025
You need to delete the EE eSIM as you no longer use that since the number has ported over to iD.
Siân
Forum|alt.badge.img+7
  • 1225 replies
  • May 23, 2025
Hi ​@WelshWife  have you managed to delete the EE SIM as ​@MZone  suggested?
Has this helped?
WelshWife
  • 6 replies
  • May 24, 2025
Thank you, but how do I delete the EE e-sim?
WelshWife
  • 6 replies
  • May 24, 2025
Dear MZone and Sian
I have deleted the eSIM personal number given by ID mobile, and now have one chosen number that I brought over from EE. Yet checking the Network provider on Settings, it shows it is still EE. What on earth is going on? I pay ID mobile but it shows EE.
Yours in some desperation . Any help given is very much appreciated.
WelshWife
WelshWife
  • 6 replies
  • May 24, 2025
I’ve been to see the mobile phone expert in town. He said there is a problem with the network coverage, it is better if I get a physical SIM from ID mobile. So thank you MZone and Sian for your help.
WelshWife
MZone
  • 1203 replies
  • May 24, 2025
  • 4153 replies
  • May 26, 2025
Hey there ​@WelshWife, it looks like you have deleted the iD SIM instead of the EE one as advised by ​@MZone, so you’ll need to request a replacement SIM card via the instructions on the link sent above by ​@MZone.
