help re phone data in Spain
  • September 25, 2025
  • 46 views
I cannot connect to mobile data on landing in Spain. Phone says you have lost data connectivity because you left your home country with data turned off. I have tried a manual reset of mobile data but its the same. I can only use phone on wifi
    Siân W
    Sorry to hear this ​@Marieact
    Please can you try following the steps in this link - I'm abroad and Roaming is not working. What should I do? | iD Mobile Community
    Please let us know how you get on.
