Help required re phone calls: signal dropping and consistent echo
  • February 25, 2021
  • 30 views
I transferred to ID in December.  Since then there has been a consistent echo on the line.  Either I can hear an echo of myself speaking or ther person I am speaking to is getting an echo at their end.  Also, regularly getting cut off from calls.  Desperately needing help as I need the phone to keep in touch with vulnerable relatives! Can anyone assist?
Coverage in my area is meant to be fine.
Mohsin
  • 2173 replies
  • February 26, 2021
Hi @Sjc2020
We are sorry to hear this. Have you tested the sim in another phone? We would like you to do this so we can eliminate if this is a fault on your phone?
-Mohsin
