help with moving number
s0ggyfrenchfry
hi, i think i’ve messed up here and hope someone can help me. i needed to change my plan and had no access to the app, so just bought a new SIM.
i assumed i could switch it over quite easily but apparently not 😅
i have finished my previous contract and tried to switch with the PAC number, but apparently you can’t use that while staying with the same provider.
how do i switch my number over (and account) onto my new plan?
thank you
  • 12197 replies
  • December 7, 2023
Couple of options:
  1. Return your new order in it’s cooling off period, and then upgrade from your iD online account.
  2. Do a triangle port.
  • 8192 replies
  • December 11, 2023
Hi @s0ggyfrenchfry,
The options that @andewhite provided are correct as we are unable to move a number from one account to another.
