help with pac
  • May 26, 2024
  • 49 views
Hi there I’ve just joined ID and I put in my pac code and it said there is a problem check everything is right and it’s all correct, but then I got a text message saying ‘we have your request to switch’
is there any way of finding out if it as gone through or if it’s processing?
thanks
Best answer by Kash
Hi @craigellery91,
  • 8192 replies
  • May 30, 2024
Hi @craigellery91,
