Hi I would like to know if I have a data cap on my ID mobile account please? If I have not got a cap then I would like one please.
Thank you
Charlotte
Thank you
Charlotte
Best answer by Tom B
Your data “cap” would depend on your allowance per month, if you have 100GB per month, you’d be limited to 100GB per month.
However, if you don’t wish to spend extra on data outside of your allowance, we’d recommend setting a bill cap in your iD Mobile app/website to £0 (or an amount you’re comfortable with).
