how do i tell what is using all my data
  • September 5, 2024
  • 8 replies
  • 252 views
How can I tell what is using my data
Best answer by WelshPaul
Your phone should have logs that tell you. What phone do you have?
iPhone:
Settings > Mobile Service > Enable Mobile Data Usage Statistics
  • 3076 replies
  • September 5, 2024
iPhone:
  • September 5, 2024
Thanks for reply I have. A Samsung s20 fe. I’m not very technical I’m afraid! It’s a refurbished phone only had a couple of months and for the first time it’s using my data fast. My previous phone was fine
  • September 5, 2024
Found it ! Might be something called smart switch which looks like it’s used a lot of data. Assume it’s when my friends son set new phone up from old one?? I’ve switched it off, will that be ok?
Tom B
  • 8434 replies
  • September 9, 2024
Hi @Kath Maddock
Samsung Smart Switch is typically only used at the set up of a device, to move device from one to another, you won’t need to use it any further if you’ve completed that process.
  • September 9, 2024
Hello sorry me again. Thanks Tom. I have purchased an add on and the phone has now used that data up so quickly again so have had to purchase another add on. I can’t see what else is using all the data ? Any suggestions please ? I only use the internet when I am at home and on wi fi so I don’t understand why it is using data so fast.
Tom B
  • 8434 replies
  • September 11, 2024
Hi @Kath Maddock
If your mobile data is being used you would not only be using internet while on Wi-Fi, the internet is also being used while off Wi-Fi.
To see what’s using the data, your device may have a data tracker inbuilt into it.
My best recommendation is to turn mobile data off in the device quick settings when you don’t want to use it, on when you do.
Thanks so much Tom. I’ll try that
Hi @Kath Maddock,
I hope that you managed to get this resolved.
