How to stop robocall?
Since last year, I received a quick call then it stops and it left voice message.  Turns out it was Chinese robocall.  Then it hasn’t stop since then, with different numbers. I set it Silence Unknown Callers on my iPhone but no feature to block it.
Anyone knows how to stop them? Thank you.
Silver Hair Deaf.
Best answer by JoeKing
@SilverHairDeaf  Another option is to block unknown number's in your device. This usually is within the Block number settlings this is different to Block with-held number's.
The down side is if any of your contacts change their number without letting you know or a number that's not in your contacts list you'll miss these call's.
Some devices have a built-in spam & scam call  blocking option check your device to see if any of these options are available to you.
Joe
  • 4228 replies
  • March 24, 2025
Hey there ​@SilverHairDeaf, sorry to hear that.
Unfortunately, all we as a network can advise is to block these calls or ignore them I’m afraid. You could also report them here if you wish:
https://www.ncsc.gov.uk/collection/phishing-scams/report-scam-call
The only other option would be to change your number which should hopefully prevent them, however, this does cost £25.00.
JoeKing
Silver Contributor
Forum|alt.badge.img+9
  • Silver Contributor
  • 377 replies
  • March 24, 2025
Joe
